I have found dodge to be very hard to get right.
But what works as well as anything, is- to loosen hood bolts enough so the hood can be slid on them.
Remove the safety catch at the front and latch, close hood and move it around to best fit.
Open jut enough to tighten one bolt on each side
Also, there is a depth adjustment by adjust the bolt-on steel plate and the hinges themselves..
This will allow more shuffle to where you want it.
These are not EZ but you will win with patience.
dont forget to re-install your hood latches.
