I've been thinking about using a fuel pump out of like a neon, an adjustable fuel pressure regulator, and a fuel injector out of a neon to create a water injection system. I would run the pump off of a WOT switch and the injector off of a boost switch or a button, so u mash the gas, the fuel pump comes on and presurizes the system, and when you reach the correct boost, the injector opens. Injectors are made to create a very fine spray pattern. I figured that I could mount the injector directly infront of the compressor wheel on the turbo. The adjustable fuel pressure regulator would keep the meth/water at the desired PSI and allow the fuel pump to run for extended periods of time (w/ return line). Anyone's input?:thumbsup
