Found a place in town that had brass mister nozzles rated for 80psi that are suppose to have a really fine mist. Comes with a removable filter. Only $3 ea.
So I rigged up my holley red to pump the water and put a bigger spring in it. I think it's putting out about 20psi now. I know I'll probably need more psi to the tip but it is misting ok now. And I'm sure the holley will eventually fail, not being made for pumping water, but this is just my prototype.
Anyone see any problem with misting the trans cooler? The problem is, there's not good access to just mist the intercooler. It's blocked by the ac and trans radiators.
I'm going to hook up my scanguage and do a couple of hwy runs with it misting and without to see if the scangauge shows an intake temp change.
