1 - 4 of 4 Posts
i was wondering if you could take the cross tubes and instead of spending several hundred on a bigger set, just find a small drill bit, mic it to get it close to .093 or .120 and use a vertical drill press. this would be the same as the expensive bought ones would it not. just wonderin if there was somethin in the center of the performance ones or not.
Got P7100?
you can drill the connector tubes to .093 if your careful
send them to me and i will drill them to whatever you want for 100 bucks. have done loads of these.
1 - 4 of 4 Posts
