1 - 20 of 35 Posts
I think if you do that you will fill up your DPF rather quickly. Unless of course you deleted it.
Compshooter, why would the DPF fill up at any different of a rate? The only difference is the color of the fuel.
I've ran it in my 2013 before and I didn't notice any difference.. Besides the price!
All fuel now is ultra low sulfur. All the new construction and farm equipment have the same emission devices our trucks have
I was under the impression that heating oil isn't low in sulfur? Wouldn't the sulfur damage these engines?:confused013:
I can't say 100% for sure, but I think the pumps at our depot for the locomotives still said 500ppm sulfur. I know that home heating oil is cheaper, but I doubt that the fines will be worth running it.
"Can I run red dye fuel in my truck"?
Many here have probably noticed the "Dyed Diesel" or "Offroad Diesel" pumps at some fuel stations or truck stops. The temptation is there to fuel up your pickup with the cheap fuel from these pumps.
However, are you aware of the ramifications? If the answer to this question is not entirely clear to you, continue reading. This is a several part question, requiring several answers.
"Can I burn red dyed diesel in my pickup truck without hurting it?".
Generally, the answer is yes. Typically "Red Dye" diesel is nothing more than regular USLD with a red dye added. Contrary to many old tales of the dye causing problems with engines, it's nothing more than myth - your engine couldn't care less if the fuel was dyed pink or purple, it'll still burn it.
In years passed (since the introduction of ULSD) reportedly SOME red-dye diesel was actually still LSD (Low Sulphur Diesel), not USLD (Ultra Low Sulphur Diesel). Trying to utilize LSD in newer trucks that specially require ULSD to run properly could present problems and possibly damage emissions equipment.
That said, since 2007 most diesel pumped at any station in the USA or Canada is ULSD, regardless if it's on-road (clear) diesel, or off-road (dyed) diesel. By December 1, 2010, all highway diesel fuel was mandated by law to be ULSD. Non-road diesel fuel was required to move to 500 ppm sulfur in 2007, and further to ULSD in 2010.
So, LSD is all but unheard of now, so red-dye or not, there's a virtually 100% chance that you are getting ULSD, and your engine will be just fine with it.
So.....
"Why is red dye diesel so much less expensive than regular diesel?"
Because red-dye diesel is designed exclusively for non-taxed off-road or commercial equipment (such as a lawn tractor, bobcat, or generator) usage. The normal taxes that are part of "regular" diesel are excluded on dyed "off road" diesel fuel, hence the lower cost.
What is "Off road" mean?
If you have a diesel generator you are not obligated to pay road-taxes on the fuel it burns, so you burn red-dye diesel. If you have a tractor on a farm that is used exclusively for off-road use, again, you are fine using red-dye diesel. If you have an UNLICENSED pickup truck that is used solely for off-road use, then you can even run red dyed diesel in the pickup truck and be entirely legal.
"Ok, but I have a LICENCED pickup truck, why can't I burn red-dye diesel?
Simple answer - because red dye diesel does not have road-taxes as part of it's cost, using it on-road is considered tax evasion. For most here, those two words are enough to strike fear into your hearts, and the decision becomes clear - DON'T RISK IT.
Don't think you will ever get caught? Sure, your luck may last years, but the government (and the people that enforce the laws on behalf of the government) aren't stupid - the red-dye pumps are watched, and random vehicle inspections are not unheard of. To the contrary, with more and more people taking the risk of burning red-dye on road, they are becoming quite frequent in many areas.
Get caught and the fines typically start at about $1000. For example, here in Ontario (Canada) the law reads as follows:
Anyone committing an offence relating to the improper use of coloured fuel/dyed diesel in Ontario is liable to a fine on first offence of $440.
Fines of up to $1,000,000 and/or imprisonment for up to two years are possible for other offences under the Fuel Tax Act, such as tampering with coloured fuel or seals and labels.
Offenders will also be audited and may be assessed tax, penalties and interest. Assessed penalties for the improper use of dyed diesel or tampering with coloured fuel may be as severe as 13 times the tax. Keep all your fuel receipts.
Picking a random US state (Montana), here's the law:
Using untaxed fuel (dyed diesel) in a licensed vehicle violates Montana's law and reduces the money available to build and maintain Montana state highways.
The penalties for using dyed fuel on public roads in Montana are:
1st offense
up to $1,000.00 - Civil Penalty
2nd offense
up to $5,000.00 - Civil Penalty
3rd and subsequent offense
Criminal Penalty - minimum fine $535.00 - maximum $1,000.00 or by imprisonment for not less than 30 days or more than 6 months, or both
Most laws are very similar with the financial penalties being higher in some, and lower in others, but in all situations it's considered a serious offence and can open a huge legal can of worms, aside from the fine itself.
Ask yourself if it's worth saving a few dollars per tank for the worry of being caught and penalized.
"I'm going to use my pickup truck off-road exclusively for a month for work, but then put it back on road - can I use dyed diesel for that one month?
In almost all jurisdictions the law uses the word "Licensed" to either allow or disallow off-road (dyed) fuel use. If, during that one month (or however long it may be) you COMPLETELY remove all licensing from the pickup truck then, technically, yes, you can use dyed fuel in your pickup truck.
Just yanking off your licence plates doesn't count, either - you will have to visit your local DMV and remove all traces of the vehicle being licensed whatsoever.
However, at the conclusion of that time period, when you re-licence the truck you will have to return to regular on-road (clear) diesel, and it would be very wise to ensure ALL traces of red-dye fuel is removed from the fuel system. Even a few gallons of red-dyed diesel can contaminate a tank full of clear diesel, and the law doesn't care how faint the dye is, if it's there, you're screwed.
Basically, you'd have to switch back to clear diesel at least 4 to 5 FULL tankfulls of fuel before you plan on placing the truck back to on-road service again in order to fully flush the fuel tank and fuel system of all the red dye, at which point you would be legal to re-licence your truck and place it back in "on road" service again.
Ultimately, if all this hassle is worth the effort and time is up to you. If you are talking a LOT of off-road mileage over a long period of time (6 months or more) then it may be worthwhile, but for a month or two, it's unlikely to be financially beneficial.
"Does the dye leave permanent traces in my fuel system, dying metal parts and leaving telltale signals that can't be removed?"
Again, this is mostly unfounded rumor. The dye does not "sink into" metals and leave any permanent traces behind once flushed out with clear diesel. The only exception may be fuel filters where the red dye can stain the filter elements and leave traces of red-dye usage, but a simple filter change will remedy any concerns there.
"So, how would they ever know? Once the fuel is in my tank they can't see it!"
Roadside enforcement of diesel fuel typically involves the officer taking a "dip" of your tank. They will lower a device down the filler neck and remove a sample of the fuel that's actually in your tank to check for dye. It's quick, and very effective.
"Can't I just refuse a roadside fuel test if I get pulled over?"
Sure, but many jurisdictions consider a refusal to test as a dire offence, sometimes equaling the worst-case-scenario fine that would otherwise result from several failed tests. You'll receive a signifigant fine and possibly even a summons to appear in court and explain yourself. In some areas your vehicle could be seized. Even if you decide to eat the costs and hassle of this, you'll find yourself on a very short list of people for future monitoring by law enforcement, so you're only inviting future problems.
"I have a large tank in my bed for fueling my equipment in the field - Bobcats, Generators, etc. I have red dye in there - is that OK?
Sure, as long as none of it ever finds it's way into the tank of your pickup truck itself, then it's no problem. Take note, however, that trucks with large transfer tanks on them are prime suspects to be pulled over by law enforcement for dye checks as the law knows that the temptation to pump some of that "cheap" diesel into your own truck is strong!
"I have a second tank with dyed diesel in it that's secretly plumbed into my trucks fuel system..they'll never figure it out!"
Yeah, they will. Law enforcement has seen ALL the tricks. Trying to secretly plumb in a second tank containing red dye so that you can flip a transfer switch and start burning red dye (while still containing clear diesel in your primary tank) is a neat trick, but it won't work - they're wise to these sorts of tactics and if the enforcement officers WILL look for secret plumbing and sneaky hookups.
.....so, with this information in hand, make your own decisions.
If tempting fate is worth it to you to save a few bucks at every fill up for your licensed on-road pickup truck, you have the information you now seek to make your own decisions.
If you have a legitimate and legal use for wanting to burn red-dyed diesel in your pickup truck, you can feel safe doing so.
If you didn't realize you could burn red-dyed diesel in your legitimate off road equipment like tractors, bobcats, generators, and the such...well, you've saved yourself some money!
hit the nail on the head ryno. same thing i tell everyone that wants to run it. i know several ppl that do. mostly farmers that have access to the fuel and its easier. i always figured they would be the ones to get caught easier however. also my uncle was caught running red. actually pulled him over for having an aux tank with no label that said "diesel" or off-road diesel only, then nailed him for the 100 gallons of fuel in the tank and the 35 or whatever in the truck. all i know is he ended up with a 2k fine for it. i just can't see it being worth it to run red fuel.
Thanks Rynosback. I wasn't aware that all diesel was now ULSD. That would eliminate any damage to the emissions equipment. But still I agree with you. It's just not worth it.
Ok, I have a question that runs along these lines. Is one of the reasons diesel is now more expensive than regular gas because it is now mandadited to be ULSD? For years I was told that diesel was cheaper than gas (back when it was) was because diesel was the bi-product of making gas, thus waste. I have never researched this mainly because I'm too lazy. But, if it is true that diesel is left over from making gas and then has to be refined itself to make ULSD! That would explain (at least partially) the price.
What's really annoying, is that within the same state, the price difference between gas and diesel can vary by up to about $.20. Example: station A has regular at $2.97 and diesel at $3.59 and station B has regular at $2.95 and diesel at $3.74. Both stations can be the same brand and both are busy with both diesel and gas purchases and less than 20 miles apart.
This is all goes for the US too
What is ultra low sulphur diesel fuel?
Ultra low sulphur diesel fuel (ULSD) is fuel that contains less than 15 parts per million sulphur. It is usually used for both on-road and off-road applications. Since Oct. 1, 2010, all on-road and off-road diesel fuel in Canada, except for rail and marine applications, must be ULSD.
Rail and marine
What is regular sulphur diesel fuel?
Regular sulphur diesel fuel (RSD) is fuel used for off-road applications such as rail and marine only. As of Oct. 1, 2010, regular sulphur diesel fuel must contain less than 500 parts per million (0.05 wt %) sulphur.
42-gallon barrel of crude oil makes about 19½ gallons of gasoline, 9 gallons of fuel oil, 4 gallons of jet fuel, and 11 gallons of other products, including lubricants, kerosene, asphalt, and petrochemical feedstocks to make plastics. [See also this EIA page] That adds up to more than 42 gallons because of something called "refinery gain" - the processing and chemical changes decrease the density and hence increase the volume of the refined components
I found this to be interesting
Lighter, low cloud point, winter diesel fuels contain a lubricity additive in keeping with the requirements of the National Standard of Canada for Automotive Ultra Low Sulphur Diesel Fuel. Petro-Canada recommends that customers avoid routinely adding additional lubricity additive to fuels as high dose rates of some lubricity additives have been found to cause problems such as sticking of plungers, metering valves or fuel injector racks.
:rof :shock::doh:That cracked me up. This is the age of google and the all mighty interwebz. You can get that answer in .0002 seconds while sitting in a chair drinking a beer
That's true, no argument there.
But, I'd rather waste time searching for fine girls oiling that oil refining!:shock::spank: while I drink a beer.:thumbsup:
1 - 20 of 35 Posts
