1 - 20 of 27 Posts
look at my sig. as of now no vp code has been thrown, but i need to put something, will a blue do ok and hold pressure right now i can 0psi it with my comp box off so i know its just a matter of time. what do you guys think.
you see what i got and i hold 18-20 idle and bout 19-15 acc. and the lowest ive seen was 10 at wot(edge on #6, Smarty, 150's...while up a hill)
With just the edge you should be fine.....12+ wot
That is almost impossible with a stock blue pump. Unless you modified it some way. The stock blue unregulated is good for 15lbs and that is unloaded.. it will drop from there...
SuperDuperMod
i cut the spring on mine and i'm holding 17-18psi no matter what, needle never moves, going on a year and a half now.
Vulcan performance for some flow through fittings and a blue should get you all the pressure/volume you need. Add some 1/2" line too while you're doing it. cheap and pretty reliable too. :hyper:
Joel's Diesel
Ya know, I did a vulcan big line kit, draw straw(1/2 inch one end to the next), with a carter 4601hp on the frame, and all I get is 12psi at idle and 9.5psi all out. Thats not too little pressure considering the volume gain, right?
There aint nothing wrong with a holly blue
Discussion Starter · #9 ·
thanks guys no how do i wire it and if i put 1/2 '' line how do i do it do i go from the tank or do i just add 1/2'' from the holley blue on. also is their a holley pump that will supply more or is a blue all i need with the spring cut. also wheres the spring and how do i know how much to cut off.
Is there any need to run a pressure regulator with a Holley Blue, or is this spring that everybody's talking about an internal regulator?
Are they all good for Diesel, or are there some out there only good for gas?
Banned
They say to put in a relay for it but i got the vulcan relo kit with 1/2 line and hooked the extension harness right to the holey and have had no iisues at all, i did 1/2 from blue to vp44 and its fine, do a small filter before the tank and it will last a lot longer. The spring is under a slotted cap screw on the base, take it out(dont loose any parts) just cut it a little at a time to get good pressure but it should be fine the way it comes, mine is 14psi at idle and never below 12psi at wot and i never touched the spring. It will be all you need, try to keep it around 15psi and all will be good the vps just need steady pressure to survive, if you need parts let me know i can help you out. DD Upstate Diesel Performance
No regulator, they are at a max of 14psi from the factory!
Discussion Starter · #12 ·
so 1/2'' from blue to vp but how do i hookup the line to the vp do i need a different fitting or what. also where do i mount the blue and when i cut the factory line is it a hard line or a rubber hose.
I have a carter p4601hp rated at 18psi on the frame feeding the stock lp. I have a Mechanincal fuel gauge that is PEGGED at 15 idle and under a throttle it sounds like its going to burst on me. It makes no sense but i believe it is possible for it to be building more pressure than dropping pressure under throttle. I cant be certain how much i'm pushing but the gauge IS at 15 and never moves. I'm doing a regulator asap. Truck also surges that may be causd by to much fuel.
Discussion Starter · #14 ·
my truck surges when going 45-50 in overdrive what causes that after 50-55 it runs fine only does it while at that certain speed and also the cruise control doesnt work very well always hunting with the pedal.
Mine surges under wide open throttle. and that fuel pres gauge is winding up high pitched and squealing. I can see it breaking and soaking my cab in diesel. i can then see me torching it and collecting insurance.
Discussion Starter · #16 ·
huh i have a 100psi autometer 2 5/8'' gage. mine is 12psi idle and i can make it go to 0psi if i want to which i dont.
When i get back home i'm just going to disconnect the CArter pusher and run just the stock lp. Hopefully that will drop below 15 or atleast get the truck to stop surging. I get home friday night and have plans to race it on sat night.
my old man runs a holley blue and has no problems with it and its been a year for him!
Discussion Starter · #19 ·
so how do i hookup the 1/2'' line from the blue to the vp or do i still use the stock filter setup.
SuperDuperMod
mines still ran through the stock lift pump and stock filter housing.
1 - 20 of 27 Posts
