I just changed all my valve cover gaskets and started the engine just to make sure everything was kosher and there's a slight hissing sound coming from down by the injection pump, any ideas? It doesnt sound like its coming from the valve covers.
Thanks!
Discussion Starter · #2 ·
bump, someones got to have some expertise.
SC Chapter President
Check the intake plate gasket under the heater grid plate, mines gone bad twice. Stupid pink gasket material!
i would check that cheap flexible fitting they have to connect the hard line to the vaccum pump, i bet their could be a leak their, just get yourself a 1.5 ft section of the right size rubber hose and cut of pieces to replace all your vaccum fittings..even if they aint that bad or thats the problem, a few bucks and you wont have to worry about vacuum leaks anymore
awesome, thanks guys...I'll update tomorrow when I get in there and find out what's what.
