1 - 20 of 22 Posts
Whats the highest HP that has been recorded with stock (non-retorqued) head bolts???
Also give tuning info if avail.
I am curious as to how well these things actually work, so far I have been very impressed, give your thoughts!!!
also subscribed
subscribed. . . also. . . but when i was looking at auroa twin turbos and they said that i didnt need bolts and that was pushing 610hp
750 is a good number
818
A lot of it comes down to the amount of timing being added and drive pressures. When drive pressure starts to sky rocket, head gaskets don't last long. If your seeing a good amount of boost 55psi or more it is just extra insurance
SNAFU
joining also i have been told you can torque to 125-150 on the stock bolt
I have heard that too, I wounder what kind of boost you can run by doing that, I have heard our headgaskets are really good and can handle alot.
Was just reading the new diesel world the other day, they said over 400 horse power or around 40 psi of boost and you need studs. My truck has been running around 450 or more for around a year and an sps 62 running around 35 to 40 psi and no problems so far. A friend of mine has made around 580 on stock bolts with an htt 64 and he hasnt had any problems either.
Bubbles
Alot!!! Jeff uses stock bolts in his race truck. Im sure they have seen atleast 75 psi
got a friend running 650 with stock studs/head. Boost to 60psi.
Northern CA Chapter President
i know a guy that hits 70+ psi daily with 62/71 twins
I am running a SPS62 and last dyno was 655hp and still running stock bolts that have not been retorqued at all. Only seeing 46psi of boost max.
damn you made that kind of numbers with a 62:shock:
that gives me hope:headbang:
So what is a safe torque number on the stock bolt? 125? 150?
Any special procedure or just start at the center and work out?:confused013:
from 05 service manual for removed head
WARNING: THE OUTSIDE EDGE OF THE HEAD
GASKET IS VERY SHARP. WHEN HANDLING THE
NEW HEAD GASKET, USE CARE NOT TO INJURE
YOURSELF.
1. Install a new gasket with the part number side up,
and locate the gasket over the dowel sleeves.
2. Using an engine lifting crane, lower the cylinder
head onto the engine.
3. Lightly lubricate head bolts with engine oil and
install. Using the sequence shown in , tighten bolts
in the following steps:
a. Torque bolts to 70 N·m (52 ft. lbs.)
b. Back off 360 degrees in sequence
c. Torque bolts to 105 N·m (77 ft. lbs.)
d. Re-check all bolts to 105 N·m (77 ft. lbs.)
e. Tighten all bolts an additional 1⁄4 turn (90°)
torque starting at center working your way out
1 - 20 of 22 Posts
