I have an 05 4x4 cummins 6 speed manual. Bought it at 53k and now there is about 63k on it. I am having a slight roaring/vibration sound and feel through the truck, which is just starting. I have done a bunch of searches on this site to find the problem however didn't come up with anything conclusive.
The sound seems speed dependent. I had a friend of mine (10+ year dodge mechanic) drive the truck and recommend it was likely a pinion bearing going bad. I have been having a weeping leak of the pinion seal, which would make sense. Bad bearing, bad alignment of the seal, thus a leak. However this weekend I took off the rear cover, and did not see any large amount of bearing metal stuck to the magnetic drain plug, nor inside the case. The drain plug had a very fine thin layer of grease like metal particles stuck to it, but nothing that screamed (at least to me) bad bearings. The difference between his opinion and mine is he says the noise stops when the clutch is pushed in, I still claim I can still feel an unusual grinding feeling through the floor board and in the petals (although less intense) that was not there before, even with the clutch pushed in. I typically feel it most between 40-65 or so on the highway. Up around 70-75 and it seems to become less and its hard to detect at all below 30. Perhaps the new grinding feeling and noise are from different problems, but they seemed to come on at the same time. I have felt for any slop in the front and rear drive shafts along with my mechanic buddy. We can not feel any slop by hand. We do however feel a limited amount of play at both outputs from the transfer case. Also it seems to do it most recognizably when backing off the gas at 40-65 or so.
My questions are:
-Is any play (up and down) in the transfer case normal? Its not a whole lot, however there is definitely a little wiggle coming from both the front and rear driveshaft (at the transfer case only) and NOT from the U joint.
-Could the U-joints just be dry and in need of replacement? They do not have any play, however from what i understand doesn't mean they aren't bad either. Would they cause a grinding/roaring type vibration?
-Is a light coating of particles on the magnetic drain plug normal? Is a bearing going bad in the rear? I changed all the fluids when I bought the truck, however do not know any of the previous history.
-Could it be the outer wheel bearings at all? Any way to diagnose this?
I thought we had it pegged to bad axle bearings, however now I'm not so sure.
Any thoughts or help would MUCH appreciated.
Thanks
-Andy
My questions are:
Thanks
-Andy
