Ok Gang!
I got it built and man that is killer to be able to kick high idle at anytime now. There is a few lock outs that you must be aware of too.
I'll get better pics in the daylight...
Ok... Here is the down and dirty on it... With all switches in the off position everything is normal. But if you start a cold engine you can flip the IAT fooler and select the mode you want to run (high or 3 cyl). Once the high idle is started turn the IAT fooler off allow the sensor to monitor manifold temps. I added a ECT fooler too and that work great too. I can fool the ECU to think the coolant is 123*F and re-kick the high idle software again. But like I found out if the software has already ran 1 cycle it will not start again. So to kick it hot you need to shutdown the engine and re-start software will activate...
WARNING: Using either IAT or ECT fooler disables the ECM/PCM from seeing the true signal from the sensors so beware you could potential overheat the engine if left on with ECT fooler on. IAT fooler should be turn off as soon as the program start to keep timing correct.
