1997 Ram 2500 Laramie SLT 98-02 Cab swap, ECLB
Title says it all, my truck doesn't seem to have a high idle, and definitely doesn't go into 3 cyl high idle. Can any truck be reflashed by the dealer to do this?
Also, can I adjust how cold it has to be to go into 3cyl? I think it sounds cool and I hate hown long it takes to warm up in the mornin. So maybe have it kick into 3cyl anytime its colder than 25 or 30? Will this cause excess wear? Thanks
You have to have a dealer enable it or do it with a Smarty tuner.
You can't adjust the kick on points, but there is a way to fool it into thinking its a specific temp.
Here is a product that is getting ready to release that will let you force it into high idle, its been 'almost done' for a couple months so I expect it should be shipping relatively soon--
Cubby mount:
High Idle Switch-Cubby Mount 1998.5-2002. Advanced Timing, 3cyl and 6cyl high idle
Gauge pod mount:
High Idle Switch-Gaugee pod Mount 1998.5-2002. Advanced Timing, 3cyl and 6cyl high idle
And the associated thread on here from the guy building them:
http://www.cumminsforum.com/forum/9...753-revised-revised-high-idle-mpg-thread.html
Awesome! Website says they plan on shipping around the end of November so I'm guessing they should be em out soon..? So with these switches I can kick it in anytime? No matter the temperature?
Go with the switch! I can't wait to get one set up on my rig!
Essentially yes, my understanding is the 6cyl you can kick on anytime. The 3 cyl as long as your coolant temp is below 170* (I may have that number wrong) you can force it in also.
Perfect! Can't wait!
