id play it safe and stay at 45lbs if you have retorqued it...some guys have blown before at 40lbs because the torque was way off...play it safe and retorque:thumbsup:ok and thank´s. is 45psi boost to much whit out studs?
i was 45 for months, the first time i sprayed water/meth i popped my head gasket. my egt's are 1750 without water/meth at WOT and 100+mphok and thank´s. is 45psi boost to much whit out studs?
