1 - 3 of 3 Posts
I have a 2008 mega cab. Bought used a couple months ago. Egr delete and exhaust is already done. When I drive around town or freeway temp is normal range. When I tow my 28 ft toy hauler temp will go to last mark before the hot red mark at 240 degrees. Has a new fan clutch in November
Thermostat could be not opening fully. Rad stack could be dirty/plugged.
Make sure the new fan clutch is actually locking up. Should make a heck of a roar and be fully on by 215ish if I recall correctly.
Do you ever have any bubbles in the overflow? Level stay in the good range?
What tuner and settings you running?
Don't know what programmer is in it was done before I got.
No bubbles in tank.
And I made sure fan clutch is engaging you can hear it working.
Possible t stat
1 - 3 of 3 Posts
