Have had HID's for about a month with no problems. Till recently. Temps have gone down since install. But they seem to flash over some bumps but not others. I checked all power and grounds and they are tight. Other times they flicker, but researching has verified my suspicion that its from the grid dropping my voltage.
I have them wired with a relay to the battery.
apply dielectric grease to the ground.
I've had lots of problems with mine like the low beams no longer work they got stuck on high beams and my power is fluctuating all over the place even with optima yellow top batteries.
I have it on all other connections. But I will add it so the ground. I connected the ground it on my existing grounds.
It was also mentioned to put in a capacitor. Not sure how that would make a difference all of the sudden.
Found a loose connection that was grounding out on the ballast. Found it when I kept hitting bumps and noticed the issue was worst at that point.
Problems is fixed.
