Oil leak from the cover post i made acutally turned out to be the head gasket. Taking care of that. Just finished pullin it off... The TST misfire i've been having heres the news...
BACKGROND...
TST reports the box is designed for a stock motor and not to be stacked with. they also say every power add on you have done to your truck pre or post tst...The lower level the box must be ran on to avoid misfire.
THE EXPERIMENT....
Put my TST comp in a friends truck with the same sticks as mine...Put my smarty in his truck as well...He even had his edge EZ in there as well. Technically his truck should have been running like crap if tst was right.
VERDICT...
His truck went REALLY fast:CRY:. I'm very upset about this. He ran TST comp on 8 &9 smarty on 8, EZ plugged in, and the 125 sticks and it was incredible. Very smooth and responsive power. His truck pulls very nice through all 5 gears. The only difference is his is an 02 5spd. mines a 98.5 auto.
I pulled off my VP tonite as well and will pick up a replacement tomorrow. I have to have a weak vp. I tried his regular tst 3 and i still couldnt run on a level above 3 w.o misfires. Does this sound like a good test? and one more thing....Any one experience #6 injector being covered ALOT more oil than the other 5 when removing it?
BACKGROND...
THE EXPERIMENT....
VERDICT...
