1 - 11 of 11 Posts
yup, its that time, after some searching im really not sure if my minds set or if I have a clue to which I really need, been looking at injectors for some time now, income tax is coming, I want a new set of injectors, as for the truck its a 91 non I/C so I think my options are limited, been debating on a set od PODs but I keep seeing their hot and really smokey, I don't mind smoke but don't want a crazy amount of it either, thought of the 370 idea, just seems like the same thing, then I saw SDX, been thinking of maybe 5x.012s, which is basically A 370 but with a correct spray angle is what Im seeing, truck has basically an untouched pump except for a couple turns on the star wheel, will be getting a denny t pin later this week, fuel screw turn, 2nd gen intercooler swap. and maybe a bigger turbo down the road, suggestions, criticism are welcome. :S:
Discussion Starter · #2 ·
anything guys? something be nice!
The "correct spray angle" is going to be the wrong spray angle for you.
Marine 370s and pods are the correct angle for you.
PODS are not a good choice, you would be way better ahead going with 370s. 370s are an EXCELLENT choice for a non I/c truck. They flow about the same as a 5x13 (slightly more than stock non I/c injectors) and will be a lot cleaner than your factory sticks (4 hole).
Also, if you want more fuel in the future... you can just simply extrude hone them... all the way up to about a 5x15 size.
okay, who sells good 370s? would I be better leaving the fuel on my pump alone and just going with the 370s and denny t stage 1 for fueling?
okay cool, ill start looking
I'll second hungry diesel. He set me up with my latest set. Can't wait to get them!
:thumbsup:
Sent using AutoGuide
Ducati M.
I'll put in another vote for the hungry diesel. Got a set from him and ended up learning some stuff in the process
Reactions: RCCUMMINS89
1 - 11 of 11 Posts
