i still gots it...:thumbsup: with a K&N no less...the stock airbox...i know none of us have them...had a warning on it saying not use it because it will cause engine damage.:thumbsup:
yeah i understand thatthe stock airbox...i know none of us have them...had a warning on it saying not use it because it will cause engine damage.:thumbsup:
Well if it was running before you changed the cam then I wonder if you have the new cam timed correctly. Beyond that I wonder if all your injection lines are air free. We also need to know what your fuel pressure is, and any codes. I'm not sure what you are looking for, but a cam change is about the last thing I would change on these engines, unless there was something very specific I was trying to achieve. Sure would be nice if you put your truck details in your signature.Okay just put a Helix 2 yesterday in my 24v. When you crank it, it blows white smoke and won't fire. When you spray ether in it, it finally fires up. It has a slight haze at idle now where as before it didn't. Before I had an ATS towing cam in it. Any ideas? :confused013::confused013:
"well theres your problem right there!"Turns out the timing marks on the crank and cam were off by one tooth.![]()
