1 - 13 of 13 Posts
Ok I just replaced both batteries and now when I start my-truck the wipers come on I was having an issue with them before the batt change I had no intermittent and they would not park back at the bottom of the windshield......
Sent from my Autoguide iPad app
Discussion Starter · #2 ·
Bump
Your combination switch on the steering column may be badthat would be my first guess
I've read that it is the motor. Some kind of sensor or something to stop it at the bottom goes bad.
That's understandable BUT what is causing them to come on when I start the truck Its crazy!!!!!
Mr. Vehicle Destroyer
the contacts in the multifunction switch get copper material rubbed into the dielectric grease that they are built with, so it shorts out a few paths on the switch and turns them on even though the switch isn't on.
you have to take the switch apart and clean the grease out of it. then relube it.
Great Thanks for the info is there any DIY's on that what directions?
Yep, do a quick search for it, there are pics posted and everything in the thread.
Discussion Starter · #9 ·
Ok cleaned it and still the same, I'm stumped
I had similar issues with my wiper motor. Wiper delay wouldn't function properly or wiper wouldn't turn off. I had to buy a new wiper motor from Steve white motors online to fix the problem. Don't get a reman you will have the same issues. I believe there is a park circuit inside the motor that takes a dump.
Discussion Starter · #11 ·
Was it the same issue as soon as you went to start the truck they come on?
No. They just had a mind of there own as soon as I turned them on.
Discussion Starter · #13 ·
See its when I turn the truck on they start for about 6 revolutions and then stop in the middle of the windshield
1 - 13 of 13 Posts
