Ok, I'm looking into some XD addicts 20x9 wheels and the appropriate tires for a summer set. I've seen 2 available BS/offset combinations online.
One is 18mm offset with 5.71 backspace, and the other -12mm offset with 4.75 backspace. I'm looking for an aggressive stance, with 1-2 inches of the wheel/tire out past the fender. Which of these 2 sizings will give me that.
This whole fitment thing is confusing to me so can someone simplify it for me?
Thanks in advance
EDIT: also, what would be a good "street" tire to put on these? These will be strictly summer tires and i do not do any "real" off roading. i have 315 70r17s on my stock steel wheels, and am looking for roughly the same total outside diameter with this new wheel/tire setup.
Discussion Starter · #2 ·
Anybody???
The 4.75 inch backspacing will give the look you are describing. As for tires, I'd recommend Toyo AT's or Nitto Terra Grapplers. And a 315/70-17 is essentially a 35x12.50 tire.
