A few things:
Have you talked with rough country about your issue, or the shop that sold it to you?
Does that kit come with a drive shaft spacer?
When you added a different drive shaft, was it the same length as the one you took off? You were not specific on this.
I had the exact same problem with my 6" BDS long arm kit. I resolved the issue by removing the drive shaft adapter that came with the kit, adding the transfer case indexing ring, and getting a longer drive shaft made. I worked very closely with BDS to resolve my problem. No issues at all now.
