21 - 40 of 52 Posts
2020 3500 HO 4x4 SRW CCLB
When I had my 04.5 smogged, they just roll a mirror under the exhaust to see what's there, hook it up to OBD for codes, and do an opacity test on a dyno.
In all the years I did that, it only failed (1st test) once because they weren't clever enough to plug in the MAP sensor connector that popped off.
Looks the same as OEM to me unless it's not yet rusted.
Automotive tire Violet Cylinder Gas Auto part
Reactions: elephantrider
2004.5 5.9cr, AFE Intake, Custom Turbo Elbow, Gauges (EGT, TRANS, BOOST), Built Trans, S06
Discussion Starter · #24 ·
No haha it's only a 2 wheel dyno here. This is what my magnaflow looks like, and coincidentally why I am concerned they will spot it.
Tire Automotive tire Automotive exhaust Synthetic rubber Gas
Discussion Starter · #25 ·
It was sadly produced as EPA compliant and is not CARB compliant.
You'd have a better chance if you, or someone, ground that birdspit off and do a nice weld job. Then use hi temp paint. I have some that matches the aluminized pipes really closely and it even harder to see a difference after a few miles on sloppy roads.
Damn, no wonder you're worried. That looks terrible.
Yet another "I do my own work" job that clearly doesn't know what they're doing. Granted, you did say that was a farm truck so they probably just slapped it on there real quick one day.
  • Haha
Reactions: AdamRRT
2006 2500 4x4, spinny wooshy thing, bigger sticks, toothpick trans, wallet weight reduction mod.
Yeah but who puts a cat on a farm truck anyway? Must be one of those hippie-type organic farmers!
Discussion Starter · #31 ·
Hahaha you guys are great, even if this **** sucks coal pipe, I'm getting a great laugh out of it. And yeah, they replaced the entire system with a 4 inch magnaflow system for some stupid reason... stocker was 4 inch I'm fairly certain. The last time the truck saw pavement was 2016 haha. And holy **** you should see the rest of the place, it's like a scrappers wet dream... if it's metal and it got used... its probably half buried in the dirt out in the woods/pens.
Discussion Starter · #32 ·
This is what the truck used to look like!
Sky Car Snow Vehicle Plant
Discussion Starter · #33 ·
That's a horse skull... not anything cool haha.
Discussion Starter · #36 ·
Haha you have no idea! They were pulling a 26ft gooseneck horse trailer fully loaded with the gov solenoid issue and the truck stuck in 3 up Cheyenne Mountain until it just stopped moving... the direct drive was welded together. I learned quite a bit about the 48re to say the least.
Poor truck. nice to see you're bringing it back to life.
My 04.5 HO 2500 before I sold it. dumb dumb dumb (but I needed a 1 Ton) and a bigger cab and more power and...
Tire Wheel Car Land vehicle Vehicle
After: Guy running a mobile welding business bought it, his first diesel.
Wheel Tire Automotive parking light Vehicle Sky
P.S. I still have a spare grill here but the chrome is bubbled. Can't seem to give it away.
You de-badged, but he re-badged?
Good catch. Except the factory Cummins badge is at the front of the fender.
Automotive parking light Tire Wheel Automotive side marker light Grille
It had Bushwacker flares on it for about a year that forced me to remove the badge from the front end of the fender. I never got around to putting it back on until I pulled them off and put it up for sale. Decided it looked better where the newer trucks have them and gave clearance if anyone put flares back on.
21 - 40 of 52 Posts
