1 - 4 of 4 Posts
Can someone help me out with the Following Codes.. P2269, P0237, P0193, P0652,P0341.. Truck Bucking/Stalling with No Power. Changed Filters & still Same.. Help Please..
Tech Specialist
p0193 fuel pressure too high
p0341 cam sensor signal
p0237 map sensor too low
p2269 water in fuel
p0652 LOW VOLTAGE AT THE #1 SENSOR SUPPLY CIRCUIT
can you clear them? what returns? check for a wire rubbing on the lines at the rear of the compressor.
1 - 4 of 4 Posts
