1 - 20 of 36 Posts
I am not new to diesels or turning wrenches but this is my first Cummins and could use a hand.. I bought a 2013 Ram 2500 mega cab 4wd and when I engage 4wd I get a popping on the drivers front only under power. It feels like an old school Chevy auto hub when they go bad. Every time I give it some power I get a ( clang, clang, clang ) until I let off the torque. If I'm just driving without giving it and real pedal it does not make any noise. Could I have some axle splines slipping or something?
Thanks
What year? CAD or not?
I'd guess CAD and it not engaging correctly.
Oops, just noticed that you already mentioned that it's a '13. Now I can't remember if that has CAD or not. Probably not, huh?
This is my first Ram I have no idea if its cad or not. I have a knob on the dash for 4x4 with a neutral button under it for 4H or 4L. It is a Laramie if that helps. If you tell me what to look for I will go outside and check.
If memory serves me (it fails frequently), the 4500/5500 got CAD in '13, the pickups in '14.
There should be a large "lump" on the right (passenger) side on the axle tube if you have it.
No lumps, it looks like a standard solid front axle like a Dana 60, no electronics, no cables. I did see that the drivers side U-joint is trash and has slack in it.
910805
910806
Sounds like you found your problem.
Discussion Starter #8
Why does it feel like slipping splines? Do you really get that much feedback from a bad ujoint on these Rams. Would you guys just replace that one or do both? Is there anything else I should replace while I have the front end appart?
Why on earth would you only replace one?!?
And I would change the seals and anything else that seems even a bit worn while being at it. Mechanical bits rarely self heal.
Discussion Starter #10
I plan on changing everything, I assume your talking about axle tube seals. Does anyone know the MOOG pn for those Ujoints? I am also going to change all the steering and ball joints if they are bad
Discussion Starter #11
Well its not the Ujoints because I just replaced them and I still have that noise when I engage 4wd. Its when I give it throttle in 4wd, it goes to clunking.
If you haven't checked it already, what shape is your transfer case in?
Discussion Starter #13
I will pull the front drive shaft and engage 4wd, if the sound is gone I will pull the T-case. I need to get this fixed, hunting season is on us and I dont have time to screw with dumb stuff. I need to go through the boat and the side by side, oh and I have 20dz decoys that need painting. Sorry for venting.
Pull the drain plug so you can check for slop in the chain. If parts start breaking in there it gets expensive.
Discussion Starter #16
Anyone have a link for a DIY walk through on T-case chain replacement without removing the T-case. I saw a YouTube video of a guy doing an 08 but I do not know if that is the same as my 2013.
I was also told that all you need to replace is the chain, the gears very rarely ever need to be changed.
911089
911090
Does that mean that you found that the chain is stretched?
So you're buying a new chain and taking the 'case apart before knowing if the chain is still good?
And if there's anything in the fluid that shouldn't be there.
Sounds like a dealership approach to me: change parts and hope, until the problem goes away.
Reactions: Electrojake
1 - 20 of 36 Posts
