Need to get fault codes read. Key trick will not work on 98.5. While cranking you might loosen a injector line and see if spurting. Check for fuel flow at VP fuel inlet banjo bolt while in key bump mode.
last question then tomorrow ill order my pumpDo not pass go. Do not collect $200.00. You stalled on Park Avenue and the rent is $1500 for VP44 and LP. Try e-bay for cheapest rent payment. Pensacola Diesel has good price along with few other quality places. Do not get CHEZ stamped or a black painted unit. All remans are equal with warranty by bosch for one year.
In warm temps (when the grid heater is inop) and used very lightly, it's not an issue. Now soaking the filter with fluid would indeed be asking for trouble. But the real reason that sticker is there is due to the cummins engine design not having glow plugs in the cyl. But rather a grid heater in the intake. During cold weather, that indeed could cause explosive problems.:doh::doh::doh::doh::doh::doh::doh::doh::doh::doh::doh:NEVER NEVER NEVER spray STARTING FLUID in a DIESEL ENGINE There should be a sticker under your hood that even says that. Thats how you blow your motor up :doh:
