should have bought a smarty :hehe: Seriously though it may be best to get ahold of superchips tech support.i have a 2002 cummins 2500 4x4 truck, i went to install the performance tune into my truck with my cortex 3950 SN#1452902, everything was going normally when it was at 44.6% download it froze and the superchips restarted as if it was just plugged in. It started back up and prompted "tuning installed", then came up "locked recovery", it required to restart saying "turn ignition of f" yes it read off like that, then asked "turn ignition on", then asked "disconnect fusible link refer to manual" manual states fusible link is for a 03-05 cummins with blue wire, i looked under the hood for a fusible link and nothing, i tried continuing with the superchip with the prompts as if i disconnected and reconnect the fusible link, and again the superchips glitched and started over as if it was just plugged in, my truck no longer starts it turns over but nothing, someone please help
thank you in advanced
