The Super B doesn't spool AS quick as the stock turbo. I found that out the hard way. It does spool quick though and will way outflow the stock turbo.thanks for the info i think i am going to go with the single b from bd. i want good power
with quicker spool not to quick for the 6 speed.
if you're gonna do the quick spool manifold also (which I suggest while you have it all apart) you'll need to get a manifold gasket set (six little gaskets) from a local parts store. Otherwise everything else is included.thanks for the info i will be looking for a turbo in the next month, mine is about dead
what do i need to install a new turbo and i also want to keep between 40-45 psi. what horsepower am i looking at?
