Yesterday I went out to start my truck and when I turned the key on everything looked good to go. After waiting for the wait to start to go out I turned the key to fire it up and nothing. It was like the alarm was still activated. I turned the ignition off and tried to lock and unlock the truck nothing would work from the key fob. Finally after checking fuses and disconnecting the power supply for the KARR alarm system I tried to fire it up again and the same thing happened. So I reconnected everything and hit the unlock on the key fob and the truck honked and blinked so I knew the alarm was deactivated. Truck started right up after that. I also noticed while I played with the wires under the dash that goes to the little eye with the button on the back side that screws onto the bottom of the dash panel the door lock will lock and unlock by them self. maybe that explains while I'm driving the door locks go crazy sometimes. Anyways I was thinking about taking the Karr alarm system off the truck cause I do not feel it has ever been right. Will my power door locks still work if I take the system off? Or any other Ideas would be great thanks. Sorrry for such a long write up.:banghead:
