The other day I ran out of fuel and primed the system, then had some trouble starting but i was enough to get home. Now it does want to start at all. It will turn over but doesn't fire. It's not getting fuel so I tried priming again (for two hours) and nothing happens . There is fuel in the filter but nothing getting to the cylinders. I don't know... could a leak between the LP and injector pump be the cause why i can't prime the system? I started to check the fuel solenoid and no cracks in boot or corroded link. Any way to bypass the LP and get fuel to the cylinders to start?
Any help would be great, I just want my truck to run again
