ok here we go my 06 wont shift if you hold down gas. it as a throttle act valve not a standard kick down linkage. The valve is new it has a new speed sensor. if i baby this and drive nice it shifts fine. Also you put it on a scanner the valve is showing 17.0 at a idle and its target is 3.0 and wile driving its showing higher then the target... has someone had this issue and how was it fixed. the truck has a smarty programmer on it and its horrible if i take the prgrammer out of it.
