looking to get a bigger turbo i have a smarty tnt revo, 100hp injectors, fass150, cold air, 6spd tranny, southbend DD clutch. what do you recommend for street and towing but will also work for 300ft pulling the sled i have a super B right now but its only rate for 425rwhp and im over 530 last i had it dyno'd i dont want to lose my streetability and towing
No Idea what your budget it, but you could keep your super B, and add bottom turbo and piping to it and turn it into a compound setup.
Super B is s300 based (almost positive) so you should be able to buy just the bottom turbo and the piping for it. Call at talk to Rip at Source Automotive. Or also Shane at Wicked has that stuff available as well.
That would be the way I would go if I already had a decent top turbo. If you go to a bigger single you are just going to add more lag to the equation.
hydraulic lifter crew
if you already have a good top turbo wouldnt adding a
second turbo with the piping be around the same price
as getting another single ?
