hey guys i just finished putting in everything and i wana fire it up and drive!!! the guy sent me the wrong wastegate bracket so i was thinking until i get the bracket am i able to tie it shut? i also have a wierd t shaped thing with a screw and nut and was wandering wht to do with that. its on the turbo threaded into the whole. what should i do?
Discussion Starter · #2 ·
anyone?????????????????????
The T looking thing look like a brass 90 with a nut and screw?? I think it is like a boost adjustor, I got one in my kit. Where did you get your kit??
Thats what I thought, I put mine on and the screw looks to be all the way out. I guess the further you run it in the more boost.
the further you turn it in the less you are feeding the big charger, you want a 1:1 on DP and you want boost from primary to be half of total so to get these numbers you will have to play with the wastegate rod and the boost elbow
