Well now its officially winter here, the last couple days highs have struggled to make it into the 20s. But now an issue that would only show itself once in a great while during the fall has now been very problematic. When attempting to start the truck, even with it plugged in, it will fire, then die, or itll just turn over and turn over and itll chug then die. Put your foot into the pedal and itll start but itll run rough for the first 20 seconds then smooth out. Itll do this engine hot or cold. I ran into the store for about a half hour, came out and it did it. I was driving down the road and coming to stop also and the truck started chugging and almost stalled, i had to blip the throttle to keep it from dying.
IDK if this is air getting into the system or my OFV. Truck has 240k miles and everything is stock. The OFV has never been touched, nor has the timing, or injectors and pump.
