1 - 4 of 4 Posts
So I too off my edge chip and It throws codes,
Po113 intake air temp sensor 1 circuit high
Po 193 fuel rail pressure sensor high
Po237 turbo boost pressure sensor circuit low
Theirs still a hole in the exhaust manifold because I'm waiting to get the other probe for the cts Any help please!!
Yes it was on stock setting, I cleared the codes and I screwed the old egt probe in and it's running right now and it has not threw any codes yet
I think you got the codes from disconnecting the wiring from the Edge harness that connects to those sensors or letting the other side touch ground or power. If you clear them they should not return.
Did you remove the harness on the engine? Was the key on?
1 - 4 of 4 Posts
