Status
Not open for further replies.
1 - 3 of 3 Posts
Hi,
I have a 2011 2500 that has started squeaking when hitting bumps. From what I can tell, it sounds like it coming from the rear doors, about head height. It sounds like rubber on rubber squeaking (or like when you run your finger over a full balloon). It's driving me crazy and I can barely stand to drive the truck anymore.
Anyone else ever have this and what did you do to make it stop?
Discussion Starter #2
I finally found the culprit for the squeaks. Turns out it was the leaf springs. Just happened to get in the back of my truck one day and heard it squeak a little. Jumped up and down and sure enough that was the problem. Seems the sound travels up the frame and into the door rails. I sprayed some white lithium grease in there and no more squeaks!
Thanks for letting us know the cause and fix.
1 - 3 of 3 Posts
Status
