1 - 12 of 12 Posts
Hellow i was wondering if anyone could help me? I have a 01 cummins with an auto trans and am not getting any torqu converter lockup. The check engin light came on, pulled the codes got a p1740 which is the Tcc or OD solinoid. I changed them and nothing changed still getting the code and no lock up. cnan anyone help?
_________________________________
01 quad cab cummins, rebuilt auto trans, super B single turbo, stage 5 jammers, BD anti defuler, edge comp with hot unlock, bullydog intake, 7" stacks, 7" skyjack long arm with 38.5 boggers.
G
Guest
Check the wiring for a short circuit. If the solenoids are good, its either not getting the command, or the signal isn't making it to the solenoids.
could be TPS (throttle position sensor) on mine it had the same thing but no codes
Go for Broke
APPS or a bad ground maybe
Does anyone know if it could be the torqu converter or the valve body? trans shifts good through all gears only no lock up.
G
Guest
You would have to do pressure testing to determine if the VB was operating correctly, and electrical testing to check the solenoids. I don't know off the top of my head what wires are for what, but there is a wiring diagram in the FSM. There is a link to a FSM in the archives here, need only do a search.
G
Guest
Apparently the link is gone. Chrysler is a bit overkill on keeping all materials regarding the products it makes under wraps unless you buy it. What year is your truck?
Sorry, now I see it on your first post. Drop me a PM.
Discussion Starter #11
Ok so i was reading some other posts and saw somthing about a manual lock up switch. I read some info on it and decided to give it a try. Got it all in and while driving about 35-40 mph flip the switch and you can feel a slight drop in rpm but if i throttle up it fells like it releases,any ideas?
_____________________________________________________________________________
did the factory offer a lock-up converter "upgrade"
I just got my 2006 2500 it was perchased at auction with 35,000 miles on it
I wanted to know how the truck came as stock
And a Dealer did a Vin# report for me
it shows in the list that it came with a 4.10 axel ratio 11.5 rear end
4-speed 48RE transmission / All 4-speed Automatic trans.
Lock-Up Torque Converter.
?Is that an Upgrade ? -Or just how all of them come?
1 - 12 of 12 Posts
