Codes on 94
Stored diagnostic codes can be displayed by turning the "ignition" key ON-OFF-ON-OFF-ON Within three seconds. The fault codes will flash on the "CHECK ENGINE" light located at about the 8:00 position on the tachometer face. This procedure works for the 94-96 12 Valve engines. The 97-98 12 valve and the ISB all require the DRB diagnostic tool to obtain trouble codes.
As an example, a 23 code would be indicated by FLASH, FLASH, PAUSE, FLASH, FLASH, FLASH. Multiple codes may be displayed, and the sequence always ends with 55. Green codes will light the CHECK ENGINE lamp when the engine is running.
CODE MEANS
11 No crank signal detected during cranking
12 Battery was disconnected within the last 50 key-on cycles (Resets after 50)
15 No vehicle speed/distance signal while driving
23 Intake manifold air temp sensor voltage too high or too low
24 Throttle position sensor voltage too high or too low (automatic only)
33 An open or shorted condition detected in the AC clutch relay circuit
34 Open or short in the Speed control solenoid circuits or
Speed control switch voltage too high or too low
37 Open or short in the Torque converter clutch solenoid CKT circuit or
Voltage high or low at transmission Temperature sensor
41 An open or shorted condition detected in the alternator field control circuit
42 An open or shorted condition detected in the Auto Shutdown Relay circuit
44 An open or shorted condition detected in the engine coolant temp sensor circuit or
A problem exists in the PCM battery temperature / voltage circuit
45 An open or shorted condition detected in the overdrive solenoid circuit
46 Battery charging system voltage too high
47 Battery charging system voltage too low
53 Internal PCM circuitry or communication failure
55 End of sequence. Last code sent to indicate the end of the codes.
62 SPI miles not being updated as vehicle travels
63 Unsuccessful attempt to write to EEPROM by the PCM
These are all of the codes that I know about on 94, and not much help for transmission problems since the transmission is Hydraulic and not Electronic, except for temp and some voltage highs and lows, and the TC clutch circuit. Codes 15, 23, 24, 37, 41, 46, and 47 should be green, but I could not get the color to change.
