I have a 2007 6.7 that someone has put a proflow dpf delete on it with the small proflow tuner that plugs in under the dash to clear the codes. After you start the truck I am getting a P0472 (exhaust pressure sensor low) P2454 (diesel particulate filter sensor a pressure low) and a P0037 (02 sensor 1/2 heater curcit low). The truck exhaust smells rich, it smokes a little more that it should on a start, and has a slight rough idle. Any help would be great.
thanks
thanks
