So ive been trouble shooting for a bad injector this whole time... but i dont know anymore... I had it hooked up to a computer and shut off each injector one at a time... i have rain caps so it was easy to hear a difference in the exhaust... trying to find which injector is bad... well the first 5 injectors when cut off dropped to the same pitch... number 6 REALLY dropped... now dodge replaced one injector when i got it from the dealer... So this didnt make any sence to me really... THEN we were checking out the fuel pressure... at WOT at redline i was only getting 16,000psi "ish" when the book said i should be getting 23,***... Now whats weird is the computer tells you what its suppose to be as you push the throttle and the fuel pressure is right where the computer says its suppose to be... but the computer thinks im suppose to have 16,000ish at WOT when the book says different??? i forget what its called... like "set" psi or something is what the computer says... So now i have no freakin clue what could be wrong... i dont have the puff of smoke at start in the morning like a bad injector... and i have the relief valve blocked so 16000 psi is all i got? could it be a FCA (fuel pressure regulator basically)??? I did the DIY CP3 Mod but i couldnt tell you if thats when my problems started... i forget... then i read about a overflow valve? do CP3's have a overflow valve on them? something about a ball and spring? really couldnt find much on that... but i think i see it plain as day in there... any ideas guys??? Thanks for the time in advance!!
