1 - 11 of 11 Posts
Just had my 04 rebuilt passed up a car heard a vormp sound saw white smoke stopped the truck had oil trail that apperied to be coming out the exhaust what's my problem?
Cummins Freak
Well, if the oil drain plug is still in then check out the oil filter then work from there. If you lost all 3 gallons that fast then it shouldn't be that hard to find!!
It's been sitting in the drive way for about a week the drain plus is still on no oil anywhere around the block just a small puddle of oil by the exhaust tip
Cummins Freak
So you had the motor rebuilt?? I would be talking to your rebuilder(unless you did it). Don't think a turbo is going to do as you are describing.
Sounds to me like a huge issue with your rings. Did you bore your block or still using standard pistons
I would take it back to your engine builder because your getting a ton of blow by to lose that much oil
1 - 11 of 11 Posts
