if your heater selector is stuck on defrost 9 outta 10 times its a loss of vacuum some where, make sure the hose was not knocked off at the vacuum pump, happens all the time, if you are working in and around the vacuum pump, also as mentioned up near the fire wall,
start at the pump and follow the lines
