So as the title says, I have two separate issues with my trucks heat/HVAC.
First, it randomly comes and goes, but more often than not my blower fan only works on high, nothing on any other setting. From what I understand there is a relay in the dash that goes bad and only lets it run on high, it seems weird to me that it would sometimes still work on other settings though. Any ideas?
Second, the heat in general just kinda sucks, turned all the way up it’s warm, but not hot, you can easily hold your hand on a vent and it’s not uncomfortably warm. Is this normal?
Keep in mind it’s winter in Montana and outside temps are often 10 degrees or less, but motor is at operating temp.
Would a winter front grill cover help heat or just help the motor hit operating temp faster? Thanks!
