i just bought a 97 12 valve and the blower motor wont work i changed the resistor, blower motor and switch but it still will not blow any ideas? thanks!!!:confused013:
Did you check the fuse?
do have power in both sides of the fuses? then check for voltage at the switch. if the switch has power your problem is between the motor and switch
do you have power to the motor?
