FYI..........if you have one of their original kits you may want to contact them for a replacement mounting bracket for the top pump.
They've been cracking on people causing damage to the truck and/or pump. I know of one guy here that already had a problem and it damaged his fan and something else I believe. I suppose due to the vibration and stress from a tight belt... the brackets can handle it.
If you take off your bracket and send it to them, they will replace it with a update version of it. The way to tell if you have the newer version or not is..... the new bracket has a rounded welded piece between the where the pump mounts and where the bracket mounts to the head.
