1 - 4 of 4 Posts
I wanted to get everyones insight on ARP Studes requiring the machining of the rocker pedestals. Is it really necessary? I know there is the whole issue with clearance of the nut to the valve cover. But i've heard a lot of people say to cut the webbing of the cover out, shave the washer down, and or just take the washer out. Just want some input on what I should do.
i'd get the pedestals cut. if you shave the washer (with a grinder) then it's not gonna be square and the torque won't be right. the washer gives the stud some more support cause its a little smaller than the hole in the pedestal. if you do it right then you have the peace of mind that it will be right. :thumbsup:
or just get the A1 12mm head studs no grinding required and they have more threads then the arp's just my .02 tho and there the same price, give or take a couple $
Tech Specialist
Try searching, that exact question has been asked and answered a lot recently.
I would save up and go with A1 H11 studs if I did it again
1 - 4 of 4 Posts
