STANDARD PROCEDURE
FRONT LAMP AIMING
VEHICLE PREPARATION FOR LAMP ALIGNMENT
1. Check for and correct any burnt out bulbs.
2. Repair or replace any inoperative, worn or damaged body or suspension components that could hinder proper
lamp alignment.
3. Verify proper tire inflation pressures.
4. Remove any accumulations of mud, snow or ice from the vehicle underbody and clean the front lamp lenses.
5. Verify that there is no load in the vehicle (cargo or passengers), except for the driver.
6. The fuel tank should be Full. Add 2.94 kilograms (6.5 pounds) of weight over the fuel tank for each estimated
gallon of missing fuel.
7. Verify correct vehicle suspension height.
The procedure that follows will prepare a suitable front lamp alignment screen.
1. Tape a line on a level floor 7.62 meters (25 feet) away from and parallel to the flat wall that will be used as the
lamp alignment screen. The level floor will be used as the horizontal zero reference.
2. An adjacent wall or floor member that is perpendicular to the alignment screen can be used as the vertical zero
reference. If there is no adjacent wall or floor member that is perpendicular to the screen, tape a second line on
the floor perpendicular to both the alignment screen and the first line, and outboard of either side of where the
vehicle will be positioned. This will be used as the vertical zero reference.
3. Position the vehicle so that the side of the vehicle is parallel to the vertical zero reference, and so that the front
of the lamp lenses are in the vertical plane of the parallel line taped on the floor 7.62 meters (25 feet) away from
the screen.
4. Rock the vehicle side-to-side three times to allow the suspension to stabilize.
5. Jounce the front suspension three times by pushing downward on the front bumper and releasing.
6. Measure the distance between the optical center of one of the lamps being aimed (head or fog) and the floor
(horizontal zero reference). Transfer this measurement to the alignment screen with a piece of tape placed horizontally
to the floor. This line will be used as the lamp horizontal reference.
7. Measure the distance between the vertical zero reference and the optical center of the nearest lamp being aimed
(head or fog). Transfer this measurement to the alignment screen with a piece of tape placed vertically across
the appropriate (head or fog) lamp horizontal reference. This is the centerline reference for the first lamp.
DR LAMPS/LIGHTING - EXTERIOR - SERVICE INFORMATION 8L - 99
8. Measure the distance on center between the first and the second lamp being aimed. Transfer this measurement
to the alignment screen with a second piece of tape placed vertically across the appropriate (head or fog) lamp
horizontal reference. This is the centerline reference for the second lamp.
HEADLAMP ALIGNMENT
NOTE: Due to the linear nature of the headlamp cutoff, a properly aimed low beam headlamp will project the
top edge of the high intensity pattern even with the headlamp horizontal reference line on the alignment
screen. No horizontal (right/left) adjustment is required for this headlamp beam pattern. The high beam pattern
will be correct when the low beams are properly aimed.
whew ...
Even though I adjusted my headlamps after the lift I still got flashed ... had to tweak the fogs also ... now only get flashed on tiny little cars and can't help them as our lamps are square in their eyes no matter what we do.
FRONT LAMP AIMING
lamp alignment.
the screen.
HEADLAMP ALIGNMENT
whew ...
