1 - 9 of 9 Posts
I’m about to swap the stock turbo to the he351cw and was wondering if you all could suggest a good air intake for my future turbo. I was looking at some nice S&B but they start for 1994’s. Thanks!
1992, 6 inch skyjacker, cross over, Borgeson, 37x13.5x20R
Two 4" silicone 45°'s and a long and short chunk of 4" tubing and a 2790 "BHAF" filter.
Thanks for the suggestion. Are you running a boost gauge?
For sure. Waste gate shut that charger will push 50 psi.
I’m new to this turbo swap... is your wastegate permanently shut or does it open and close as needed?
At first I bought the “adjustable waste gate spring kit” from the hungry diesel....... not even close to adjustable the way I got it....... so after playing around with some springs from the local Lowe’s I found one that will open right at 30psi. Not perfect to were I’d like it to be but its better than nothing.
What size injectors are you running?
1 - 9 of 9 Posts
