I am looking at a that setup, He351+FBD or coaltrain 150s, my question is, has anybody done it and had any success(with EGT's ect)? :confused013:
I know I can run a HX35/40, but the HE351 is alot cheaper/newer and have super fast spool up.
Thanks,
Chris
Banned
he351= 60mm. Think i might try that as well, because this cat turbo is way smaller than i expected
Do yourself a favor and cut the wastegate hole out bigger. It ought to help a little.
Got P7100?
:ditto: Should be able to go to at least an inch with no problems.
I was going to do this exact setup till i decided to buy a different truck.
I think it would be a good setup:thumbsup:
I've done it to two of them, first one I used a die grinder on and the second I set up in a drill press and used a 1 inch drill bit. I wouldn't use a die grinder again, way easier with drill.
