1 - 9 of 9 Posts
I am posting for a friend. He has an 06 and he has to start it every time with ether. I just found out that he has been doing this. After it starts it runs great but I forgot to ask him if it smoked after start up. What could be the cause. My thoughts were injectors or cp3?
Tennesse Chapter President
more than likely an injector is leaking off pressure. I am almost 100% that is what mine is doing. I can crank and crank and never start without ether. Yesterday we checked all the injectors and the are all firing, number 1 less than others. Then this morning I isolated the #1 injector and it started right up, so Monday I am ordering an injector.
the part I used to isolate it was...miller part # 9011, got it from my snap-on dealer for $20, Geno's also has them.
:agree2: its either the rail prv or a leaking injector. I can't believe how many people use ether on these trucks to force it to start when obviously something needs to be fixed otherwise it would start on its own :banghead:
You guys might think im stupid but first thing i wouldnt be using too much either if any to start these new diesels.
I don't use ether on anything unless its a last resort. If it normally starts fine without ether then suddenly doesn't start its time to fix something not just pour ether in it weather it be gas or diesel.
I wouldn't use ether! That stuff is horrible on diesel engines. If you use it too much, it will become dependent on it. Have you considered a pump issue? Either lift or injector. I had the same issue on my 99 dodge. My lift pump would go out, and after going through a couple of those, my lift pump went out due to lack of fuel lubricating it. Instead of using ether, I got a shop rag, put a little bit of gas on there and stuffed it in the air intake. Now you might want a second person to do this so your truck doesn't suck it in. Your truck will not suck the gas, its just using the fumes to get it going and get a natural vaccuum to get the fuel to the engine. Something to consider.
:rof :rof : rof :hehe: :hehe: I have nothing good to say about the previous post its all wrong other then saying check out ur lift pump but that's unlikely to be the culprit here.
1 - 9 of 9 Posts
