1 - 2 of 2 Posts
I've been thinking of putting a 10' camper on the back of my truck, but I'm worried about the high center of gravity and side winds making it tough to drive. I'd like to keep the 4WD, but drop the truck down to the same height as a 2WD.
It seems like the easiest solution would be to swap over suspension mounts and coils from a 2WD truck, but I'm not sure if there would be clearance issues for the front driveshaft or other parts.
Any thoughts or advice?
I had a 03 3/4 ton and hauled a 11'4" camper without any problem. I did put on air bags, on th rear and helped a bunch. Good tie downs is also a must. It does take a little while to get used to the sway, but I assure you, you will not tip over. I now have the same camper on 05 1 ton dually and love it.:confused013:
1 - 2 of 2 Posts
