I am having some problems with my truck, after it has been sitting all nite and I go to warm it up like always it has started taking a few extra seconds longer than normal, and then after driving it for 2 hrs straight and stop at the store for a coffee refill and turn the truck off to go in, when I come back to start it it will crank and crank and crank, I only run the starter for about 4 -5 seconds and then retry, it some takes it 10 to 15 mins of this procedure.... Very confused just thought you guys might have an idea, and the problem started about a 2weeks ago kinda over nite, it has all new filters, you think all injectors are taking a crap at the same time....no white smoke at start up either:banghead::banghead:
If your confidant the batteries and starter are good, next step is probably the injectors. How many miles? Whats the rail pressure while cranking?
Don't know the rail pressure while cranking, but I will check this morning, and the truck just hit 220k, once it gets started it seem to run normal.
Ok started her up, started fairly normal to the way its supposed to....rp while cranking is 0 psi, it doesn't register any thing until it running.....:confused013:
:S::S::S::S::confused013::confused013::confused013:
